FS> Corded remote
Posted 13/02/2010 - 19:12
Hi. Does this fit the ist DS? If so so, can I have it please!
Tony
Tony
Posted 13/02/2010 - 22:13
I do not think this works with your camera, sorry
Edit, It could be for the MZ series of cameras
Colin
Edmund Burke (1729 – 1797)
Posted 14/02/2010 - 08:16
OK, thanks very much for checking.
Tony
Tony
Posted 14/02/2010 - 17:16
The cable with a switch on one end and a 3-pin socket on the other is for the MZ series.
Two/three (or more) years ago, someone put the instructions on the 'net for making one using components from Maplin. This involved cutting down a 4-pin socket to three pin. OK, if you were handy with a soldering iron, a craft knife and a file, and it looked like it would work. There was no voltage problems as the wiring involved "making" the right pins in the right sequence to get the auto-focus followed by the shutter release. Do it the wrong way round and the results could be interesting.
Anyone want to try this on the K...D series bodies?
Geoff
Geoff
X-5
istDS
K2000
P50.
X-5
istDS
K2000
P50.
Posted 14/02/2010 - 19:23
If anyone's interested in making their own MZ series remote, I knocked one up for my MZ-M a few years ago on the basis that £1.50 of Maplins components and 20 minutes' work was a better bet than paying Pentax £30 link.
The connector is the same as the data connector for a computer CD drive. On AF MZ cameras, you need three of the connections to operate AF and the shutter release. With the manual MZ-M, you just need two, connected to a momentary make-and-break switch.
The small Maplins switches fitted perfectly into a section cut from a disposable pen, with a cable running out the other end of the pen barrel and soldered on to the CD connector. This wouldn't work if you also want the AF function because you'd need two switches. In that case, you'd have to fit the switches into a small plastic "project" box.
The top-most two connections on the MZ-M trip the shutter. The lower one and one of the other two (I don't know which) operate the AF. I'm beginning to wonder is life's too short for this sort of tinkering.
Al
Al
Posted 14/02/2010 - 23:53
Aero wrote
Now you really have me intrigued. :
All my CD/DVD drives have a IDE connector (2x20 twin row). Do you mean the CD Drive to Sound Card connector? My first thought is that the MZ series pins are at about 2.3mm spacing, while the Sound Card connector pins are more like 2.7 centres. I don' have my Maplin catalogue handy - of course.
Geoff
.The connector is the same as the data connector for a computer CD drive
Geoff
X-5
istDS
K2000
P50.
X-5
istDS
K2000
P50.
Posted 15/02/2010 - 01:13
You're absolutely right, DoctorJeff. The old memory's playing tricks. It is indeed a sound card connector. I think it was described as a "CD drive to sound card connector" or something similar. You'd have a heck of a time carving an IDE connector down to fit. Thanks for pointing this out.
Al
Al
Posted 15/02/2010 - 10:01
So I started out to find the original article that I mentioned. What I did find was that there was a lot of confusion between the CS-205 switch as used on (e.g.) the K200D, the Cable Switch F, as used on (e.g.) the MZ-50 and MZ-M, and the Remote F for the IR control. Did not find the article (memo to self: look through the files of "old camera stuff").
Did find:
http://martybugs.net/photography/remote.cgi
which is a home-brewed CS-205 (fits a lot more than Pentax). Do note that you will need a 2.5mm coax plug with three wires to it (think cheapie stereo earphones for a music player).
http://www.photosig.com/articles/1088/article
which is a bit short on DIY detail, but illustrates the use of the sound-card connector (see aero's post above) but just calls it a "computer connector".
And if you are really adventuresome - there is some software around that will turn your PDA with IR into an IR Remote F. That one does get a bit "techie", and you need the .NET framework on the PDA, but it might be fun to try.
Did find:
X-5
istDS
K2000
P50.
X-5
istDS
K2000
P50.
Posted 15/02/2010 - 21:17
Anyone else nostalgic for the simple days of a plunger-style cable release?
K.
K.
Posted 15/02/2010 - 21:50
I'm getting nostalgic for when this was a Classified Ad....please try to resist starting discussion threads in Classified as the attempt to sell something gets lost in the process.....
Bedford
Approx 1Metre long remote shutter release cord for Pentax Film & Digital Cameras
Great condition.
Has a plug on the end with 3 sockets in it (not for K10d)
Asking £7.00 inc P&P
Can email picture if required
