Focusing with Sigma 170-500mm lens
CHEERS Vic.
Regards, Christopher
ChristopherWheelerPhotography
Good questions! Firstly I have NOT gone into the settings to de-active the shake reduction. I used to have a switch on the back of my K10 so forgot all about that!
I did secure the Lens to the Tripod and not the camera. I used the lens both hand held and on the tripod but had hold of the camera when pressing the shutter button! So that could be the cause of the issue I suppose?
I will try taking more images using the lens and tripod combination this weekend and will de-activate the vibration and see if that resolves the issue.
Best Regards,
Paul
Pentax K5D, Pentax 16-45mm f4 DA ED AL, Pentax 55-300mm ED, Pentax 100mm Macro f2.8 D-FA, Tamron 28-200mm, Sigma 170-500mm.
Whilst in the Bird Hide, I usually use a Manfrotto G-Clamp then insert the top section of my Tripod center column with Ball head.
If the weather is Ok I plan on going out into the Hills this weekend and will give everything a try.
Best Regards,
Paul
Yecora99
Member
Manchester
Last year I bought a used Sigma 170-500mm APO DG lens for use with my Pentax K7 and K5 DSLR.
I can obtain reasonably decent sharp shots when used at close distance (if the subject is within 10 meters) however when I try and shoot wildlife which is further away my shots appear to be out of focus or the focus point is not on the subject itself.
Can anyone advise me on how to improve my technique.
Whilst talking about using this lens I have used it on a Velbon Tripod with a Calumet Ball head is that the best tripod head for using this lens or should I get one of those heavy duty tripod heads or a Gimbal?
Best Regards,
Paul
