Focusing issues on Pentax cameras
Posted 26/07/2017 - 13:47
LV doesn't look at the camera settings. It just opens/closes the aperture in 2 stop steps to get the proper picture on the LV screen at least on the K-5. I think other marques will allow the aperture to be selected. (Maybe the K-1 does? )
Still not much use unless you have some sort of micro adjustment on the lens focus to get within +/- 7mm. A focus rack is easier, but you still have the problem that it will probably only be correct at that one distance.
Posted 26/07/2017 - 15:11
There is also the problem of focus shift. Lenses can change the point of focus when stopped down. They more often than not also change the point of focus (very dramatically) when zoomed.
Fortunately, the amount of precision we can achieve is sufficient to ensure top quality results.
Posted 26/07/2017 - 16:31
pschlute wrote:
If i want to absolutely nail focus to the best of my ability on a subject i will use a tripod and LV viewed at 100%. with the lens wide open if needed. Tell me a better method?
From Sabas's test of liveview with electronic shutter, it might lead to a sharper image for more reasons than just focussing (seemed shutter vibration could have been an issue.)
Posted 26/07/2017 - 17:02
Yes John , I experienced the shutter shock myself when using speeds in the range 1/30-1/200. But I am talking simply about focussing. When using LV zoomed 100% the big screen on the K1 makes manual focussing so much easier than using the viewfinder. The image is much much bigger. No use at all of course when off the tripod or with a moving subject.
Posted 26/07/2017 - 17:11
I'll have to have a play trying that (be interesting with that 300 2.8!)
Posted 26/07/2017 - 18:43
That is exactly the FL (+ longer) where you will notice it
Posted 26/07/2017 - 21:47
Yecora99 wrote:
I also own an Olympus OM-D EM-5 DSLR and the focus point on that is spot on.
A minor point, but I can't let it go uncorrected. I also own an Olympus OM-D EM-5 DSLR and the focus point on that is spot on.
A mirrorless camera by definition is not a DSLR.
They are MILC cameras, though Panasonic coined 'DSLM' which I like better
Posted 26/07/2017 - 22:01
....and being a mirrorless camera presumably uses Contrast detection AF which has no need to be adjusted, like LV on a DSLR
Posted 26/07/2017 - 23:14
pschlute wrote:
We've just gone full circle. See my reply immediately after the OP's original post!SteveLedger wrote:
....and being a mirrorless camera presumably uses Contrast detection AF which has no need to be adjusted, like LV on a DSLRYecora99 wrote:
As to DSLR, that's the abbreviation for Digital Single Lens Reflex which describes the fact that a mirror or prism transfers the image to a viewfinder. The Oly doesn't have a viewfinder and mirror or prism hence the DSLR description is not appropriate. I don't believe they make DSLR's any more.
Posted 27/07/2017 - 06:23
Depends on the mirrorless camera.....and being a mirrorless camera presumably uses Contrast detection AF which has no need to be adjusted, like LV on a DSLR
Like the Pentax K-70, some cameras have phase detect autofocus sensors on the camera image sensor itself. These span right across the sensor, so aren't limited to the centre area like a typical DSLR.
20 years
Surrey
Sorry if my post was confusing about Live view. i did not mean to imply that the LV Contrast Detect system has anything to do with autofocus adjustment.
