Flash does not fire
Posted 21/06/2018 - 11:12
Morning Andy
Daft suggestion, have you got the shutter speed set to the correct sync speed or below ?
Chris
Posted 21/06/2018 - 11:49
Tried that, no good, even pressed the test button, no good , so I think the flash has given up the ghost. Thanks
Pentax K1-ii and MZ6
ONE UNITED Member
ONE UNITED Member
Posted 21/06/2018 - 12:19
Did it not work on the K3 either then ?
Stuart..
Stuart..
Posted 21/06/2018 - 12:28
Sounds like it then, presume you've double checked the batteries are loaded correctly, have you looked to see if the terminals in the flash are corroded ?
Chris
Posted 21/06/2018 - 13:10
Have you fired the flash off camera to check if the flash itself is ok?
Posted 21/06/2018 - 15:37
There is an item in the K1 menu were you set the type of flash response cant remember which... But im sure you will have already set it...
Stuart..
Stuart..
Posted 22/06/2018 - 09:25
I think a trip to a Pentax dealer is required to get a compatible flash.
Thanks all.
Thanks all.
ONE UNITED Member
ONE UNITED Member
Posted 22/06/2018 - 10:27
Worth considering the Cactus RF60x and a Cactus V6ii trigger, lets you use the flash so normal and combined with the trigger full sync up to 1/8000 sec.
The flash would be about £130 and the triggers are around £60, the flash has a build in receiver so you only need a trigger for the camera when used on a stand
Chris
Posted 23/06/2018 - 13:59
Might consider that but I don't use flash very often.
ONE UNITED Member
ONE UNITED Member
22 years
Handsacre
Thanks Any help will be appreciated.
ONE UNITED Member
