Fixed iso and aperture
duster
Posted 02/01/2019 - 14:43 Link
I'm trying to set up a user mode on my K3 that will give a five shot bracketed exposure with a fixed iso and fixed aperture. But I can't figure out how to do it or if it's possible.
Any ideas?
Nigelk
Posted 02/01/2019 - 15:38 Link
On a K5II just use Av- Aperture priority, this just changes the shutter speed to adjust the exposures. Probably the same or similar on other bodies. These days I do exposure bracketing manually, gives you total flexibility and control.
duster
Posted 03/01/2019 - 09:21 Link
Unfortunately, Nigelk, that doesn't work. although the aperture is fixed, the shutter speed and/or the iso is altered. I want to have fixed iso and aperture. Also I want to do it hand held for HDR. It may not be possible.
bforbes
Posted 03/01/2019 - 09:27 Link
Does Nigel's suggestion not work if you take the ISO off the Auto setting?
derek897
Posted 03/01/2019 - 09:33 Link
At least 1 of the 3 values has to change otherwise it's just the same shot.
I think you can set the range of iso, to a minimum, but something has to change,
Or am I just not understanding your point ?
duster
Posted 03/01/2019 - 09:39 Link
Yes, I just want the shutter speed to change. I'll try limiting the iso range - never thought of that! Sometimes the obvious doesn't leap out!
richandfleur
Posted 03/01/2019 - 09:45 Link
Five bracketed photos with fixed iso and aperture only leaves the shutter speed to vary the exposure.
If you have a fixed iso then this should work fine. I found changing the iso settings a bit difficult at first, but you definitely should be able to achieve what you are after.
Edited by richandfleur: 03/01/2019 - 09:45
duster
Posted 03/01/2019 - 13:34 Link
that's the answer. Av and limit the iso range.
thanks everyone
derek897
Posted 03/01/2019 - 13:35 Link
Glad you got sorted
