FF compatible lenses for K-1
Posted 04/05/2016 - 14:10
Hi, we put together this list:
https://www.ephotozine.com/article/pentax-full-frame-and-aps-c-lenses-29263
We'd love to add any more we may have missed,
Josh
Josh
Posted 04/05/2016 - 17:03
Josh
Well, there's all the old lenses that you've missed out, or is the list meant to be just current ones?
Josh
Posted 04/05/2016 - 17:24
The list is covering those currently available new.
The longer list might contain many hundreds.....
Posted 04/05/2016 - 18:02
True, but I'd rather see Pentax lenses listed that you can get for pennies than 3rd party lenses that cost a packet.
Still, it's not that sort of a list.
Posted 04/05/2016 - 18:29
One thing I've wondered, does anyone know why Pentax continued to produce a small number of FA series lenses after the last film SLR was discontinued, and produced them alongside the DA range?
Was it the case that those in particular were seen as still required on aps-c for some reason ..... Surely the ongoing demand from actual film SLR users could never have justified it?
Posted 04/05/2016 - 22:46
Probably simply that people kept buying them. Do you remember the 50mm f/1.4 fever that struck here a couple of years back? It's an ideal portrait focal length of course, on APS-C. The Limited lenses were also legendary for quality and they still have it today. If they sell, then why not keep them going.
Of course now they all have a new lease of life with the K-1. Unless it was a Long Game and the intention was always there, so they were kept at the ready.
Posted 05/05/2016 - 12:36
To answer your question Nigel, the FA lenses that continued to be produced had no direct DA/DA* substiture, the DA35f2.4 doesn't quite replace the FA f2 version, and the FA50 f1.4 has no direct replacement; the 200 and 300 were replaced by DA*, and the DA*55 somewhat occupies the slot vacated by the FA*85.
Now that the K-1 has at long last hit the shelves I would possibly expect the old FA versions superseded by HD D-FA variants with in-lens AF.
AKA Welshwizard/PWynneJ
Posted 05/05/2016 - 18:06
That makes sense, thanks, plus of course the matter that Pentax must have believed they would keep selling, as John implied. Lets hope we do get the modern DC motors and HD coatings in updated versions for the future!
Posted 05/05/2016 - 21:13
The only way to see if a lens is full frame compatible is not to rely on someone's untested data but to try the lens and see. Take the DA70mm f2.4 limited for example which isn't on that list. This proves to be perfectly fit for full frame use, The only non full frame aspect regarding the 70mm is that it sets the camera to crop mode!
I've just taken an image of a newspaper (full double page spread) in room light, hand held at 1/80sec, full aperture (f2.4), ISO 1600 and cropped off all but the bottom left hand corner 982 pixels from the 7360 present in it's width (showing what Photoshop calls Actual Pixels.) This is quite a test for any lens in not ideal conditions and this is the result.
Stopping down, putting the camera on a tripod and using a lower ISO would presumably make it much sharper but for normal shooting it's probably no worse than using the FA77mm Limited. I certainly wouldn't feel the need to rush out to swap it over for that FA equivalent.
Posted 05/05/2016 - 22:21
12 years
Warwickshire
Pentax - 12 no.
Sigma - 7 no.
Tamron - 5 no.
Samyang - 7 no.
Irix - 1 no. (2 variants)
Schneider - 3 no. (a bit esoteric these)
That is a total of 35 lenses in a range of primes and zooms, tilt-shift and macro, from 14mm up to 500mm.
