Visit MPB Visit MPB Visit MPB
EXIF Settings
Carol8345
Posted 15/11/2016 - 10:11 Link
For some reason my EXIF settings never show up. I normally load my photos into Adobe bridge and then edit. Could I be doing something wrong?
petrochemist
Posted 15/11/2016 - 10:18 Link
How are you saving them?
Adobe strips EXIF if you use the save for web option.
I've never understood why, my copyright message (added to EXIF automatically by the camera) is MORE use for images on the web than those stuck on my hard drive...
Carol8345
Posted 15/11/2016 - 11:29 Link
I do use save for the web. How else do I get them jpeg otherwise?
JAK
Posted 15/11/2016 - 11:38 Link
I find saving as tiff causes loss of exif, even if subsequently reimported then resaved as a jpeg. Some editing programs have an option whether to save the exif or not, so may only require a tick in a box somewhere.
Just don't use save for web if you want to keep the exif intact. If it's to upload here, resize to 1000 pixels and just do a normal jpeg save.
Most web sites now have their own server software to resize/make the image suitable (often ImageMagik) so not much to be gained from 'save for web' anymore. It's now just considered a legacy option and treated as such in recent PhotoShop editions.
Edited by JAK: 15/11/2016 - 11:52
petrochemist
Posted 15/11/2016 - 12:17 Link
I think there's an export option, but I rarely use adobe.
Algernon
Posted 15/11/2016 - 12:22 Link
I read somewhere that Adobe always write over maker data with their junk
Edit: Something about here (from 2010 to 2016)
https://forums.adobe.com/thread/743437
Edited by Algernon: 15/11/2016 - 12:33
JAK
Posted 15/11/2016 - 12:45 Link
Yes, Adobe certainly does. I think part of the problem is that manufacturers aren't consistent in the use of some of the the fields meaning they cannot be described/identified accurately.
Discussed here: http://stackoverflow.com/questions/1320881/exif-key-names-explanations
petrochemist
Posted 15/11/2016 - 13:19 Link
JAK wrote:
[quote:3496ace15f="Algernon"]I think part of the problem is that manufacturers aren't consistent in the use of some of the the fields meaning they cannot be described/identified accurately.
No the problem is that lightroom just doesn't bother with it. There are other fields in EXIF that are specifically for processing data which is where Adobe should put 'it's junk'
'Exif.Image.ProcessingSoftware' sounds like the perfect spot
It doesn't need to understand the existing data, just reproduce it.
Many other graphics editing packages such as FastStone preserve the EXIF, by default.
Edited by petrochemist: 15/11/2016 - 13:35
Posted 15/11/2016 - 13:46 - Helpful Comment Link
Just use "Save As" instead of "Save for Web", after you have resized of course.
truckerathome
Posted 15/11/2016 - 15:48 Link
When you save for web there is an option to save exif under the metadata tab. Set the dropdown on " all " and most of the exif required is saved. There are a couple of other options as well, one of them being "none". Presumably this is how yours is set if you are using Photoshop
Martin
Carol8345
Posted 15/11/2016 - 23:57 Link
Thank you! Save as works, now I can post my settings.
