D-FA 15-30 focus direction
Posted 30/11/2018 - 17:25
Mentioned in JR's review at ePhotozine https://www.ephotozine.com/article/hd-pentax-d-fa-15-30mm-f2-8-ed-sdm-wr-review-... .... fourth paragraph.
Surely its not really a problem given it's a very wide angle with AF ?
[quote="JR"]The number of times I would want to manually focus this lens are few and far between, so it may no longer be an issue at all.[/quote]
Posted 30/11/2018 - 17:36
[/quote]It's a game stopper for me. Been trying to use the lens today and I just can't get on with it. So it will have to go.
Posted 30/11/2018 - 18:26
Stick with it, don’t be hasty, it’s a fine lens.
Posted 30/11/2018 - 18:48
Performance wise, it is a fine lens. But for me, the handling sucks. If I keep it, it will never or only very rarely be used so it will go as soon as the all the deals are over.
Posted 30/11/2018 - 18:58
Whenever I manually focus I move the ring back and forward around the focus point until it is sharpest. Cannot say i even notice if I am turning clock or anti-clock wise.
Posted 30/11/2018 - 19:02
In a way, that is exactly my point. I use manual focus a lot. Generally I do not need to think about which way to turn it. It has become "ingrained" so that it goes the right way -EXCEPT - with this lens. If I had bought it from anywhere but SRS it would be already on it's way back under the distance selling rules. However Chris does a lot to look after us on this Forum and so I will not use that in this case.
Posted 30/11/2018 - 20:15
Me too. I've some lenses that focus (and zoom) the same way as Pentax ones, and some that are opposite.Whenever I manually focus I move the ring back and forward around the focus point until it is sharpest. Cannot say i even notice if I am turning clock or anti-clock wise.
I can't say that it's something that I ever think about - I just twist back n forth 'til I get there
Posted 30/11/2018 - 20:36
A question? By this do you mean you autofocus and then make any adjustment by turning back and forth? Or are you talking about manually focussing with the AF off as I am?
Posted 30/11/2018 - 21:42
Posted 01/12/2018 - 10:49
Yep it's due to the base lens being made by Tamron. I noticed that the switching between the focus and zoom rings in newer designs has caused me a bit of annoyance in recent times too.
All the gear with no idea
Posted 01/12/2018 - 11:01
More than the "base lens". The lenses are MIJ. Ricoh hasn't had a factory in Japan for some time. The lenses along with the 24-70 are made in Japan by Tamron with the Pentax mods and different finish/coatings for Pentax. Probably quite lucrative for both Pentax and Tamron. Maybe the reason Tamron sells the lenses under in own name for Canikion but markets such a "poor" selection for K Mount.
Posted 01/12/2018 - 11:23
Kim C wrote:
Both really. But I mainly only manually focus with old K/M manual lenses. I don't really enjoy the MF experience with most AF lenses, whichever way the ring turns...
A question? By this do you mean you autofocus and then make any adjustment by turning back and forth? Or are you talking about manually focussing with the AF off as I am?pschlute wrote:
Posted 01/12/2018 - 11:27
I find that far more of a PITA than than the zoom/focus direction.
Posted 02/12/2018 - 15:34
I have to agree with KimC
The question of focus direction has been going on for years, and I certainly remember it being a topic back in the '70s.
The general view was that Pentax and Nikon went one way, while Canon, Leica. and Minolta went the other.
3rd party lenses? My guess is that it depended on sales volume - those that I have handy in Pentax K mount work in the direction that Kim would expect - even a Vivitar mirror lens in T-1 mount. Of course, the distance from lens to film plane could be a factor when deciding which mounts to market a lens for (or in).
What was considered of equal importance was the focus "throw", or the amount the focus ring had to be turned from closest to infinity.
I have a Tamron A2 lens 24mm/f=2.4 which moves in the Pentax direction, with a short throw, and it will take a **non clamp-on lens hood on the focus ring, the clamp screw is long enough to make a handy focus lever.
Made a handy walk round lens when I could still walk.
Geoff
Geoff
X-5
istDS
K2000
P50.
X-5
istDS
K2000
P50.
22 years
Lincoln
I am finding it a real PITA as it goes against "instinct" and every time I try to fine tune the focus, I initially go the wrong way. Anybody else find this?
