Cyberlink power director 13 on Laptop - can it work please?
Same should be true of the flash drive transfer
- Does your laptop have a dedicated graphics card, or just the one integrated with the CPU? Dedicated cards are much better for video
- Does it have a SSD (Solid State Drive), these are much faster than traditional hard drives
- The more RAM the better, 8gb is just about workable, 16gb would be a whole lot better
A core i5 processor can come in lots of different guises, some are better than others. In general an i7 is better than an i5, but it's the whole package and how all the components perform together that determines the end result. Sorry if this has confused you but there isn't an answer as simple as 'yes' or 'no' to your question. It also depends on the size of the video files you are processing and what file format they are.
There's a simpler answer to your flash drive question; 'yes' Cyberlink will be able to open it from a flash drive.
It will run, but how well it runs depends on a lot of different factors:
Indeed David you have over-complicated a very simple problem with the answer still yes.
The spec is in the op so should tell you that it's not an ssd, 8gb runs the majority of all modern pc's perfectly well unless running multiple mining and computational threads but Intel's hyperthreading happily takes care of those tasks. The graphics element will has significantly improved with each new incarnation of Intel's current cpu's so onboard will cope with videos easily. The spec tells me there will be something meatier under the hood.
So Louise, the answer is still yes, and yes
Not sure, how do I find that out?
Again not sure. Can I add more ram to a laptop?
How can I find this out?
I only edit HD video
I don't think these are HD.
I can only give it a go. I haven't opened the CD drive yet since buying this laptop
link
https://www.facebook.com/pages/Photographs-by-an-angel/262352847143059
link
Sorry, but I totally disagree with you. I think Louise's responses above justify me raising these points. It is massive over-simplification to state that PowerDirector13 will run satisfactorily on an i5 with 64 bit OS. Yes, it will run better on a 64 bit OS, but not just because it's 64 bit and only if you have sufficient RAM, sufficient Graphics power and CPU processing power to go with it. My son has a 64 bit Windows 8.1 OS with 8gb of RAM and a processor equivalent to i5, but it DOES NOT run PowerDirector satisfactorily with anything other than very small video files. Anything of significant size causes stuttering, poor responsiveness and general poor operation, which BTW does not occur with other video processing software such as Sony Vegas Pro 11.
If Louise's laptop does not have dedicated graphics, does not have a SSD for example, then I think it might struggle with anything other than small tasks with small video files. There is a huge range in performance terms of laptops with core i5, Win 10, 8gb RAM and 2tb hard drive storage. Without knowing the specifics of the performance of her laptop and the type of processing she wishes to do, there is no way anyone can confidently state 'Yes' it will comfortably handle it.
BTW, my working life is spent working with PC's in a commercial environment.
It's this one
link
Let me know what you think?
link
link
These are all very comprehensive video editors full of details and precise ways to control your video files and fine tune the output.
They also are considered to have a high learning curve and are regarded as the least intuitive of the mainstream editors I believe. I found this myself, but wanted to persevere as the level of fine control is amazing, and to this end I bought Steve Grisseti's 2 books on Vegas Platiumum 11 and the DVD Authoring program that is included as well. I've read and re-read the books 3 times and there's still things that catch me out and I have to keep going back to the books again and again.
That said, for the committed, it is very rewarding, and I love my DVDs that I've created with a number of 'home movies' on and their title pages and little opening video sequences that play .... all very professional looking. But I must say that the effort to get those results was very high, and I am not currently doing any video editing as I find it quite taxing.
Is Sony Vegas Pro 11 very good? My laptop has 8gb and has two TB memory.
HDD space is referred to as 'storage'.
'Memory' is the amount of RAM installed, which in your case is 8Gb
I'm not sure what you are doing with Video and what your end goal is, but there's a free open source video editor available which has a shallow learning curve, is fast to load and use, has a simple but attractive UI and importantly the output is of good quality. The program is regularly updated with a new version posted each month.
It's called 'Shotcut' and I use it for all my video editing these days.
► http://www.shotcut.org/bin/view/Shotcut/WebHome
Just to fade in show holiday clips nothing fancy) and then fade out. I never heard of shortcut I'll check it out.
Do you drag the files to a timeline?
link
link
Absolutely you can do both those things in Shotcut with great ease.
Watch the tutorials, in particular Cross-Fades and Transitions. It's dead easy.
► http://www.shotcut.org/bin/view/Shotcut/TutorialVideos
12 years
Salisbury
I've tried running it on my PC which runs Windows 7 with 32 processor, but it doesn't seem to run very well on there.
Also my next question is:
if I save the video file on a flash drive from my PC and transform it to my laptop after installing Cyberlink. Will I be able to open it?
I don't want to have to upload the files from my handycam again (which will be a hastle).
Thanks very much.
link
link
