Couple of lens questions
Re. the 50-200, the obvious way to go would be to get the DA55-300. I traded up last Xmas and have been very happy with the results. The 55-300 is definitely a step up both in terms of image quality and range. The extra 100mm would certainly be useful for your candids.
Mhuni
500px
Dave
2. the DA 55-300 is seen here as best in his range.
You also have the Tamron & Sigma 70-300.
Tamron is sharp but has CA problems,
Sigma doesn't have those problems but isn't really sharp at the long end,
Pentax is the best compromise between these.
Stefan
K10D, K5
AF-540FGZ
Of course if you want something really good then I think Amins DA* 60-250mm is still available in the classified section.
. My Flickr
1. I have the 50mm 1.4. It seems really soft at under f2.8, by f4.00 it is sharp. Is this normal? I ask this as this lens was attatched to my K100D that got destroyed when it was soaked. I am now using it on my new K20 and when I zoom in on an image it looks soft (almost blurry) but is fine by the time I go upto f4. Could it have suffered some kind of water damage?
2. I have the 50-200 kit lens and I really enjoy the range of it. I like getting candid portraits at the long end. What would be a good replacement for it to get a better quality lens?
Thanks for any help
50 F1.4 is very soft wide open with low contrast. Its far more noticeable on a camera like the K20 at 100% (14M) than the K100 (6M).
Not unusual for lenses in this class. See here....
http://www.photozone.de/pentax/126-pentax-smc-fa-50mm-f14-review--lab-test-repor...
The 55-300 is a nice lens but not a major step up in IQ or speed terms (and its performance tails off a bit beyond 240mm). If you want a major improvement then you need to look at the 60-250 F4 which is a stunning lens.
Cheers, Steve
I never considered the 55-300. Because it had a longer range, I thought it would be an inferior lens!!
Also, the extra range at the lower end is something you don't get with the 70-300/70-200 options
But you don't know what soft is until you've seen the 50 1:1.2 wide-open!
Mhuni
500px
The 70-200 / 60-250 are what I would look at if I had the money, but if not by all means get the -300 but for it's extended range rather than expecting a 'class up' in quality.
I couldn't have taken the shot in the link above (handheld, by the way) with my 50-200, both because of length and it wouldn't have been that sharp.
Regarding the more expensive faster telephotos - no doubt these would be more of a step, but then that depends on whether nigelp wants to fork out the extra dosh and is happy with the bulk of the 60-250 or 70-200. I'd say the size of the 55-300 makes it a more practical lens for candid photography. But up to now I've avoided bulky lenses, so I'm not really in a position to comment on how viable these are. But I have been very happy with my 55-300.
Mhuni
500px
2. The 55-300 is the obvious choice, it's a better lens in all optical respects than the 50-200. It is larger though which might limit its usefulness for candids. The lovely thing about the 50-200 is no one realises how long it is until they see the photos, as it basically looks like a standard short zoom.
but it does help
nigelp
Member
Thanks for any help
