Cleaning sensor Kx
Posted 13/03/2012 - 21:00
I thought I had one of those once but it was a mark on the monitor! Just dismiss that possibility first.
John
John
Posted 13/03/2012 - 21:04
I had a similar problem on the KR recently. Consensus is that you avoid a wet wipe of the sensor, and do that only as a last resort.
A rocket blower seems to do the trick. Or you could always: https://www.pentaxuser.com/photo/sensor-cleaning-43395 LOL
KR, Pentax 55-300 DAL, Pentax DA 17-55, Pentax 35-80, Generic grip, Generic remote, Nissin Flash. HISTORY - MZ 50, MZ 60, *istDS, KM, K20D, Nikon F60, Nikon F90. Large assortment of Point and shoot film and Digital, Sigma 70-300 APO DG, Samyang 500mm mirror lens, Sigma lenses of all assortments. K20D now sold. Sad to see it go, but makes room for an eventual upgrade to the K5 or the K4?
Posted 13/03/2012 - 21:07
DON'T touch the sensor with anything but the correct materials! Unfortunately the correct stuff is ridiculously expensive...a rip off in fact, but the sensor is probably the most expensive part of the camera body so it's worth it.
Regards,
Michael
Michael
Posted 13/03/2012 - 21:39
You can clean the sensor with a pec pad slightly dampened with isopropyl alcohol - it must be damp, not wet. Bear in mind when doing this that you will not be touching the sensor as it has a filter over the top of it. Make sure there's no dust on it first (use a blower) and wrap the pec pad around a wooden spatula with a flat end. Carefully drag this across the sensor with a very light pressure.
If you do this carefully, you will not damage the sensor. Many on here have done this.
Posted 13/03/2012 - 22:32
I had dust on my kx sensor before xmas. I researched a lot, but before investing I bought a rocket blower from amazon for £7.99.... It worked brilliantly. Just remember to hold camera up so that mirror and sensor is facing floor so as u blow the air the dust falls out rather than getting stuck!
Posted 13/03/2012 - 23:00
JamieT wrote:
Arctic Butterfly for me
"And me!"
Posted 13/03/2012 - 23:15
beginner wrote:
And me.
"And me!"Arctic Butterfly for me
Barrie - Too Old To Die Young
Posted 13/03/2012 - 23:39
Price of the Arctic Butterfly is well over the top. I suppose it lasts a long time and is reusable. However, you can buy wet sensor wipes on E-Bay cheaply. They are on a flexible stem so that you dont accidently place too much pressure on the sensor. They are pre soaked in Iso Alcohol.
Rocket blower is cheap. I would exhaust all the cheap alternatives before buying the "butterfly"
I bought a USB vacuum. It has very little sucking power, but just enough to suck up the dust blown around by the rocket blower. Dont put the vacuum actually into the cavity, also dont put the rocket blower into the cavity too far. Ensure you have good battery power or the mirror lock may drop onto your blower, then your problems may really start.
Posted 14/03/2012 - 13:37
thanks guys, i had a rocket blower but cant find it, might have to buy a new one.
thx!
thx!
Digital: KP, Film: KX, ME Super
Sigma 10-20mm f4-5.6, Tamron 17-50mm f2.8, Pentax 16-85mm, Pentax DA 20-40 ltd
Pentax 21mm f3.2 ltd, Sigma 24mm f2.8 macro, Pentax 28mm f2.8, Pentax 35mm f2.8 macro, Pentax 43mm f1.9 LTD, Pentax 50mm FA f1.7, Pentax A 50mm f1.7, Pentax K 55mm f1.8, Pentax DA* 55mm f1.4
Metz 36 AF-4
Metz 36 AF-4
Posted 14/03/2012 - 14:44
I had my K-10D sensor filled with dirt. I opted for the wet cleaning method with swab and solution. Bought it from e-bay for about £ 17 and cleaned the sensor myself. The sensor now is unbelievably clean. Not a trace of dirt. I had used about 5 swabs, so much was the amount of dirt.
If the swab leaves some residue, clean it again with a fresh swab with just one drop of the solution, with little extra pressure on the swab against the sensor. You will have it clean.
Regards,
Jeeess
Regards,
Jeeess
K-5, K-7 and K10D, Pentax 18-135 WR,18-55 WR,Pentax 28-105,Sigma 28-300, Sigma 28-80 (Macro) and Pentax 50-200 WR.
Posted 19/03/2012 - 10:05
I bought a new KX, attached the kit lens and after a month or two noticed loads of dust spots on the sensor. This was incredibly frustrating as I'd never detached the lens - I couldn't understand how this much dust could suddenly appear.
I bought a generic air 'bulb' and spent ages blowing the sensor. Probably 50% of the spots were removed this way. The other 50% were stubborn.
Reading a million reports online (including scare stories) I eventually thought I'd give a wet clean a go. I bought a special swab and cleaning solution, swabbed the sensor - and success! Well, almost - one stubborn spot remaining.
Another swab this time exerting a little more pressure on the spot where I knew the dirt to be - and FINALLY - one clean sensor.
I've since bought several other lenses, regularly swap them when out and about in all types of conditions and I've never suffered a dust spot since. Very strange.
In general, ignore the scare stories - these things are not half as delicate as people would have you believe. Use a non abrasive swab and you should be ok. Personally, I won't hesitate to clean it this way again when needed.
However, only you can weigh up the cost/risk of a DIY approach.
Posted 21/03/2012 - 18:44
I have to do something about this soon, last time I tried the camera refused to lift the mirror because it felt that the battery level was too low, even though they were almost new at the time. I will have a look around for rechargeables I think, having seen the cost of the AC Adapter.
Posted 21/03/2012 - 22:46
Mike, I would thoroughly recommend you get some Sanyo Eneloop rechargeable batteries. They are brilliant and cheap on Amazon. They work extremely well with the K-x.I have to do something about this soon, last time I tried the camera refused to lift the mirror because it felt that the battery level was too low, even though they were almost new at the time. I will have a look around for rechargeables I think, having seen the cost of the AC Adapter.
Berlin
noticing the same dust spot on every picture - i used the dust removal tool inside the camera but it doesnt really help - is there a way to clean the sensor without damaging it?
there is a way to leave the mirror up but i am worried about how to clean it / the right cloth to use?
thx
Metz 36 AF-4
