Checking out a Pentax SMC-A 35-105mm F3.5 - focus scale oddity
The short end of the 35-105 is noticeably longer than the 35mm prime, ie the magnification is significantly greater.
This is consistent with the zoom ring not moving all the way to the 35mm end of the scale, as shown in my earlier picture of the lens.
So I'm increasingly suspicious that there's something wrong with the lens.
Still grateful for any comments about whether this sort of thing is normal. I've never seen the focus scale issue on any lens before, however, so I'm highly suspicious.
i'd return it. Something is not right. It could have been dropped or taken apart and not reassembled properly. There are plenty of other good examples out there.
Yes, totally agree with the above.
Chris
Samyang 14mm F2.8, Pentax DFA* 70-200 F2.8
K.
My website
ChrisA
Member
South West London
A friend has bought a SMC-A 35-105mm F3.5 for her son, who has a K1000 and is getting into all-manual B&W photography.
I'm checking the lens over for her on my K-3 before she gives it to him, and I've found something rather odd about it.
Cosmetically it's excellent, verging on mint. The front and rear elements could do with a clean, but they're undamaged. The aperture control is smooth and the iris opens and closes perfectly.
The focus and zoom rings are tight and smooth, just as you'd expect for a good example of one of the old A series lenses. Exposure isn't bad, indicating that the lens is stopping down correctly.
However.... I've noticed two oddities - one minor, one potentially major.
The minor one is that the zoom ring doesn't go all the way to the 35mm marking at the wide end, as you can see here.
The major one is that at all distances, the focus distance scale is miles wrong. For instance, at the 105mm end of the zoom I can focus on chimneys half a mile away, and the focus scale says 3m (yes, three meters). At the 35mm end, the effect is even more pronounced - I have to shift into macro mode to get the same chimneys sharp with an indicated focus distance of under 1.5 m.
I've got the K-3's AF set to use the center spot only, and the visible sharpness in the viewfinder corresponds to the in-focus hexagon. I've also tried the lens on my K5-IIs and the issue is exactly the same.
I can't believe this can be right - it seems like there's something very wrong with the internals, but I'd be grateful for any thoughts or comments.
I've cross posted this at PentaxForums - hope that's ok but as my friend has only a very short time to decide whether to give the lens to her son or return it to the eBay seller, I was hoping for as wide an audience as possible. Thanks in advance.
