Cheap Macro Flash
Posted 18/06/2014 - 15:23
Should work ok. Why do you think it won't?
From Amazon specs;
•Compatible cameras: Canon, Nikon, Pentax, Olympus, Samsung. With host adapter: Sony
From Viltrox site;
Compatible camera Camera with standard hot shoe
From Amazon specs;
From Viltrox site;
Posted 18/06/2014 - 15:27
It looks the same as a Vivitar 5000 which I have. That works fine except that exposure setting can be a bit of a hit-and-miss test. I gather that there are other incarnations of the same thing under different names. If you get one make sure that it comes with all the lens rings.
Posted 18/06/2014 - 15:29
kh1234567890 wrote:
It looks the same as a Vivitar 5000 which I have. That works fine except that exposure setting can be a bit of a hit-and-miss test. I gather that there are other incarnations of the same thing under different names. If you get one make sure that it comes with all the lens rings.Should work ok. Why do you think it won't?
I've had two of the Centron types and the only issue I've got with them is that the batteries go in the body of the flash unit and the whole unit is connected to the end of the lens.
Posted 18/06/2014 - 15:34
JohnX wrote:
OK. That one looks cleverer than mine. But mine cost me all of ten quid.kh1234567890 wrote:
Spring Onions by kh1234567890, on Flickr
Posted 18/06/2014 - 19:24
I have the Viltrox and can wholly recommend it; HOWEVER it has/had problems with the K5II/K5IIs, have a read through this thread over on Pentax Forums.
I've had no problems with either my K5II (with latest firmware)or K3.
Here's one with the K3, DFA100 WR and 1.4xHD.
And here's a DFA 100WR lens hood modified to take the flash tubes without putting addition weight/restriction on the lens barrel, IIRC I used/modified the 62mm ring that came with the flash.
Hope this is of some help.
Brian.
Brian.
Posted 18/06/2014 - 19:47
I've gone ahead and bought one from eBay as McBrian has said it works fine on his K5II. Do you know where I can get the latest firmware for the camera and how I go about updating it? Thanks.
_________________________
Pentax K3
Vivitar 28-200mm f3.5-5.3 A Macro
Tamron 90mm f2.8 SP DI Macro 1:1
Pentax smc DA 55-300mm f4.0-5.8 ED
Sigma 30mm f/1.4 EX DC
Pentax 18-135mm WR
Pentax K3
Pentax 18-135mm WR
Posted 20/06/2014 - 14:56
I've got my flash now, I updated my firmware to the latest version v107. The problem I have is that once the flash goes off I have to press the pilot button once and then the flash works again. If I don't press the pilot button in between using the flash each time then the flash doesn't work at all. I suppose it's better than other peoples problems where they have to turn everything on and off to get it to work. Does anyone have a solution?
Pentax K3
Pentax 18-135mm WR
Pentax K3
Pentax 18-135mm WR
I'm looking for a cheap macro flash as the Pentax and Metz ones are quite expensive. I found one that seems decent the Viltrox JY-670, however from reading some comments it seems it doesn't work with the Pentax K5II. Anyone know of a similar macro flash with tubes like that instead of LEDS? Thanks.
Pentax K3
Pentax 18-135mm WR
