Visit MPB Visit MPB Visit MPB
Carl Zeiss 50mm f1.4 Planar T* ZK on Pentax K5 & Pentax K1
kasperbergholt
Posted 15/02/2024 - 19:21 Link
Clever people,
I'm considering getting a Carl Zeiss 50mm f1.4 Planar T* ZK lens (Pentax K mount).
Being manual focus, will it communicate exif, priority & shutter values to the camera body on the K5 and the K1? I have its cousin, the Milvus with my Nikon D3 where all values are passed on to the camera, so I would assume it's the same with th K mount version even if it's an older model.
Huge thanks in advance,
Kasper
-- Kasper Bergholt
Posted 16/02/2024 - 00:21 Link
I don't think most of those things are properties of the lens (whatever it might be) so there is nothing for it to communicate. They are all generated by the body. What the body will not record is the f value set on the lens (unless it has an 'A' setting.
My page on Photocrowd
kasperbergholt
Posted 16/02/2024 - 09:15 Link
Thank you for the swift reply. So basically the Zeiss lens would work the same way as my 77mm 1.8 limited in manual mode? So that auto mode would function - and the camera beep (if set to do so) when objecsts are in focus for example?
-- Kasper Bergholt
Posted 16/02/2024 - 23:50 - Helpful Comment Link
It should indeed bleep - but remember that the bleep is a guide, not a guarantee! When the camera is set to manual you will have to use the green button to set the correct exposure before pressing the shutter release.
kasperbergholt
Posted 18/02/2024 - 11:12 Link
Makes sense - thank you for the feedback - it's appreciated
-- Kasper Bergholt
Jonathan-Mac
Posted 19/02/2024 - 10:49 Link
Unless the lens has an A setting on the aperture ring, which I don't think it does, it will not communicate anything to the camera. You set the focal length and the camera will write shutter speed and ISO to the EXIF but the camera won't know the setting of the aperture so won't be able to write it.
The AF beep is a guide and to set exposure use either the green button to tell you a setting (also a rough guide) or chimp as necessary. Make sure the camera is in M mode.
kasperbergholt
Posted 20/02/2024 - 08:23 Link
Thank you for the feedback, appreciated! It does have a values from 2 to 22 and a 'A' setting at the end of the dial. So I guess it should work in the same way as my current go to lens, the 77mm 1.8, but without autofocus. There's a 35mm 2 in the same series, it looks amazing.
-- Kasper Bergholt
Posted 20/02/2024 - 22:22 - Helpful Comment Link
You didn't say it had an 'A' setting! That WILL transmit aperture data back to the camera and vice versa and you can use AV, TV and TAV, controlling these from the camera E dials. But no AF. You can also use the F series 1.7x AF adapter, if you have one. This will increase the focal length (by 1.7x) and also costs a couple of aperture stops of light but you do get excellent AF. That 'A' setting opens lots of possibilities.
kasperbergholt
Posted 21/02/2024 - 17:14 Link
Lucky me! & thanks again for the feedback
-- Kasper Bergholt
LongTimeLurker
Posted 21/02/2024 - 18:42 Link
To expand slightly on David’s last post, the use of the ‘A’ setting in the aperture ring provides all functionality apart from auto focus. This makes for a lens that is quick and simple to use in one the camera programme modes.
I have a copy of the 35mm f/2 model: it is one of my two favourite lenses. As it happens, I often use it with the camera in manual exposure mode and the Pentax ergonomics make this a breeze.
There’s one on eBay (UK) at the moment. Not promoting the sale nor do I have an affiliation with the seller, simply to point out a copy of the lens that isn’t easy to find unless you buy from Japan. Very pricey mind, even taking into account the relative rarity.
Nigel.
pentaxian450
Posted 21/02/2024 - 21:11 - Helpful Comment Link
You can use "catch in focus" with a manual focusing lens. When CAF is activated, you hold the shutter down while focusing, and the shutter will release as soon as the focus is confirmed.
kasperbergholt
Posted 23/02/2024 - 09:22 Link
Thank you for the feedback & your personal recommendation of this lens - out of curiosity: What's the other?
I checked out the one for sale, very nice glass. I'll need to check up on VAT handling post-Brexit - but I think additional costs would be the same as ordering from Japan (but these listings seem higher, but, on the other hand, some of them offer refunds & guarantee). What remains clear, I think, is that one of these will be mine some day not too long into the future
-- Kasper Bergholt
kasperbergholt
Posted 25/02/2024 - 16:08 Link
Hello again - by great chance three 35mm lenses were listed previously today on eBay ex-demo from Rare & Mint in Austria (meaning no added VAT versus the one listed for sale from the UK).
Ordered one 5 minutes ago. Looking very much forward to receiving it
-- Kasper Bergholt
LongTimeLurker
Posted 04/03/2024 - 00:20 Link
I can imagine you're excited
Let us know how you get on with it when you've had chance to use it.
You asked earlier what what my other favourite lens is, well it does depend upon my mood ... it is usually either a Voigtlander 58mm f/1.4 on the occassion I need a slightly narrower field of view than the Zeiss 35mm f/2, or when a moderate telephoto is needed I use a Voigtlander 180mm f/4. The advantage of this mix of lenses is that they feel and handle very similarly, indeed they are all made by Cosina of Japan.
For my style of photography, a manual focus lens with auto-exposure (the green 'A' setting on the aperture ring) is perfect. When taking pictures of the youngsters in the family, use of the catch-in-focus feature as mentioned by Yves works very well.
Nigel.
