Capturing dark skin
better to slightly over expose then pull back in post processing.
here you'll find a couple examples I did recently:
link
the best technique I know of for dark skin, involves polarizing your light source and a polarizer on your lens to have control over highlights, which probably is goin to far for your needs.
if you got lots of natural light, use it and a reflector, and maybe a little (set to manual powered right down low) flash for a catchlight in the eyes...
JR beat me! note : JR is correct for shooting jpegs, I shoot RAW and do post processing in Aperture and Photoshop...
So natural light with a gold reflector to bounce some light back to warm up the image. Try -0.5 exposure compensation OR over-expose and shoot in RAW.
Hotshoe in slave mode (might need to read the manual) to light hair?
Try to talk them into a white background that might go a bit grey - lots to think about - thanks, I think!
K7, K100d, 18-55mm kit, 50-200mm, Sigma 70-300mm, 50mm f1.4, 16-45mm f4.0, 50-135mm f2.8
look at the dark skinned subjects carefully and you will see a patten...
to seperate a dark subject from a dark background, you need a separation light behind the subject pointing towards the subject.
you could do black background and use the flash to seperate the subject from the background, then reflectors to bounce light on the subject.
Meter carefully. watch for shiny highlights.
link
link
you really need to get proficient with your lighting set ups before you shoot an impatient subject... practice before the day and post some sample shots and maybe I can get more specific...
a shoe flash should be able to throw a wide enough beam.......just be careful not to get it hitting the lens straight on or you'll get lens flare.
I will try to light them from one side highlighting the hair. I will also try to reflect light onto the side/back of the head. I will get some shots downloaded for you to comment on after the shoot - if that is OK?
love to help.
I'd go this route if I were you...
flash from behind, two reflectors one on each side..
aperture set to prevent the highlights from the flash from blowing, then lower the shutter speed until the ambient light balances the image...
hope that helps...
or just natural light if it is good..
