cactus v6 II with pentax firmware and rf 60 latest firmware
.... is it me or this forum is becoming a bit desolated?
Here's the thread .....link
I think I tried everything with the cactus except multi flash support, what didn't work for you?
The two features with the V6II / RF60x and the X-TTL firmware that I have not been able to get working are the 'Flash Compensate' and the 'Flash power lock'. I have tried a few times and it just doesn't happen as I read that it should. It is not helped by the fact that there is no full Instruction Manual for the X-TTL firmware version, only a Quick Guide. However I seem to be experiencing a bug, unless I am doing things totally wrongly.
As I read it, the Flash Power Lock applies to TTL mode, and is supposed to hold a fixed flash output level while the function is active, even when the framing might be changing. So its meant to be like a temporary switch to manual power. ...... But I can't get it to work ....
The 'Flash Compensate' is supposed to apply to Manual HSS mode, and should automatically adjust flash power to compensate for changes shutter speeds ....so you should be able to adjust your ambient exposure without affecting the flash exposure ...... but, I can't get it to work
Is the flash also on channel 1 ?
Also the trigger on the camera must be set to TX and the others if they have a flash connected to RD. I have one trigger I've set up with a yellow dot on so I always use this trigger on the camera, saves any hassle when I need them on a shoot.
I also switch the triggers on first then the flash as I've found on the odd occasion when I've done it the other way, it's not worked.
Hi Stan
As far as I can see I have the triggers set to Group A and Ch1 and have tried the camera in all the modes through to Master and Controller without success. IIRC there was a way to trigger Pentax 360 without the small on camera flash operating but that is something else. On one of the Cactus triggers I get a message Dial Locked and can't seem to find any reference to that. I think I'm going to sit with a note book and write down what I do if I get it working. Maybe a project for the "Dark Nights". Even looking online I have to use ctrl and + to increase the manual to a readable size of font. Am just starting to use flash, for water splashes and the like as I don't get out and about for photography like I used too.
You mentioned "remotes" ..... Plural. The RF60 flash has the receiver built in, so you only need one V6 on the camera, as Chris said in Tx mode. No V6 receivers are required. The channel and group is set directly on the RF60 flash.
Also don't worry about the camera flash modes .... They have no significance when using triggers. The only thing to be wary of on the camera is not to exceed 1/180th sec (this assumes you are using the older V6, not the V6II.
Hi Stan it's not a simple system at all, so stick with it, I'm sure we can sort out the problems between us all.
Have you downloaded the Pentax software update from the Cactus web site for the 6ii Triggers ?
Settings wise, on TX all I think is required is the select " P " for Pentax. On the RF60x - select " S " for slave and ensure the channel is the same on both the trigger and flash.
On the second trigger, again it'll need the software update, and you'll have to select the flash your using by name, in my case I use a Metz 64AF1
HTH
So far Stan has referred to " V6" ......
13 years
Southsea
P.S.: is it me or this forum is becoming a bit desolated?
