Beginner's guide to lenses suitable for Pentax cameras
Posted 18/05/2012 - 14:56
Actually, I think I've just found the answers to most of my questions:
http://www.robertstech.com/compat.htm
~Pentax K-5, DA 18-55mm f/3.5-5.6 AL WR, DA 35mm f/2.4 AL, DA 55-300mm f4.0-5.8 ED, FA 50mm f/1.4, M 50mm f/1.8 - flickr
Posted 18/05/2012 - 17:57
Get a 403 error on that link
http://kmp.bdimitrov.de/lenses/index.html
M42 lenses need an adapter. As the dSLR has no means to control the aperture on M42 lenses, life is easiest if they have an auto/manual switch; set to manual and you can control the aperture on the lens.
Be careful with lenses with the infamous Ricoh pin (PK/R); do research before mounting them on the camera as you might have a hard time getting some of them off.
Some K-mount lenses (e.g. Vivitar 70-210) have a large shield to protect the aperture lever. This will prevent them from mounting on a dSLR (and, if I'm not mistaken, SLRs that support powerzoom); a small surgery makes them usable.
Lenses for other camera systems (Canon, Nikon etc) can be used with adapters; you might however loose functionality (AF lens is no longer AF etc); personally I don't bother about them.
Hope this helps.
Hope this helps.
Garnett
Member
garnett
Basically I want to know which will autofocus and which won't, which will fit straight on a K-5 and which need mounts, and which are good for a beginner like me to look out for and where to look to get them a reasonable prices.
So not asking too much then!
