Battery 'meter' just pulses when I put certain batteries in my K5II
Posted 13/03/2017 - 18:15
If some work and some don't, it sounds like those that don't are knackered.
Posted 13/03/2017 - 18:27
If they weren't holding a charge I'd agree, but they are. They'll get binned anyway, but I hate mysteries!
Posted 13/03/2017 - 18:47
Tony
“Twelve significant photographs in any one year is a good crop.” – Ansel Adams
Posted 13/03/2017 - 18:53
Did they ever work in the camera? If not then they sound to just be dodgy batteries. I have no problem with non Pentax batteries in my K5II, or inn charging them with the Pentax charger.
Posted 13/03/2017 - 19:18
Thanks Gwyn and Fishbones.
The batteries used to work fine in the K5II, and as said, it's three out of four batteries from the same supplier, all bought at the same time and outwardly identical.
Posted 14/03/2017 - 08:26
open circuit voltage only equates to charge if the battery has no other faults. A dodgy cell could be dropping out under load.
Posted 14/03/2017 - 10:47
Don't bin them as they're classified as hazardous waste, send them for recycling.
Posted 15/03/2017 - 01:52
Battery voltage should be verified with a load on the battery. Even a "dead" battery could indicate full voltage without a load applied.
Posted 15/03/2017 - 10:16
Thanks for the additional comments. Presumably the charger is simply using voltage as an indicator of charge state?
Are there any 're-conditioner' chargers for these batteries? I have one for AA's and AAA's which has revived a few in the past.
JohnX
Member
South London
When I measure the charge they are 8.01, 8.04 and 8,24V.
When I put them in a charger the green light goes out almost immediately.
When I put them in my K5II the battery 'meter' on the top LCD pulses, the camera makes a clicking noise in time with the 'meter' pulse, and that's it. Nothing else lights up.
Other batteries with the same voltage work fine.
All three with the problem are generic ones off eBay, but so is one of the one's that works and was bought at the same time as the problem three..
Anyone any ideas what's going on please?
