Visit MPB Visit MPB Visit MPB
Asahi Pentax LX 'Sticky Mirror Syndrome'
Peter Elgar
Posted 03/07/2020 - 17:10 Link
hi All --- I have two Asahi Pentax LX one bought 1987 the other s free gift from Pentax House ( RE -- the Famous FIRE Story) BOTH have then infamous 'Sticky Mirror Syndrome and both had exposure troubles!
I have cured the Exposure Troubles by Rotating the Exposure Compensation and ASA dials back and forth as on the ME Super, to clean the contacts underneath and both agree with my Weston Master V and on film gave good exposures now BUT the 'Sticky Mirror' drives me Nuts ! I had a look -- there are two very small 'Mirror Rests' , slightly different from 1987 model to the later model -- could i put a very small amount of Iso-Propyl Rubbing Alcohol OR Lighter Fuel ( Butane) on them to see if it cleans off any 'sticky' surface ?
Benz3ne
Posted 03/07/2020 - 17:50 Link
I’d say yes, but be judicious in your application. Use a cotton bud and remove most of the “bud”, so there’s little cotton. When you apply the isopropanol (I’d say it’d work better initially at removing gummy bits), Dan lightly on a paper towel before working lightly.
Might leave a chalky/powdery residue after full cleaning so wipe down, again carefully, with naphtha and you should have a clean mirror again!
Posted 03/07/2020 - 23:55 - Helpful Comment Link
Mirrors should never be touched to clean them, the front surface silvering is fragile. But Peter wasn't referring to stickiuness on the mirror surface, but stickiness in the flipping action of the mirror mechanism. I think an overhaul would be the surest way forwards.
pschlute
Posted 04/07/2020 - 04:16 - Helpful Comment Link
I think all LX cameras suffer from this. Mine certainly does. I tried a little talcum powder on mine and it improved things for a while. I dont think alcohol will help* and may make things worse. The rubber pads have decayed and some solvents may eat into it.
Another solution I have not tried is to file a pencil lead until you have a small amount of powder then apply this to the pads.
* Well alcohol may help....you can have a little drink after you have pressed the shutter and are waiting for the mirror to lift !
Edited by pschlute: 04/07/2020 - 04:18
Peter Elgar
Posted 04/07/2020 - 09:45 Link
John Riley is right -- it's not the mirror SURFACE or the Foam Mirror Bumper which is still good on both LX cameras -- it takes about 4 seconds from pressing shutter release to mirror finally moving up and shutter firing! WIFE has forbidden me to 'Spend Money on my Old Cameras' so I wanted a DIY solution if possible. I was given a great MINT Chinon CG-5 Pentax 'K' fit which has NONE of the Pentax ME Super and LX exposure problems where you have to rotate the Exposure Compensation and ASA Dials back and forth to clean contacts underneath and NO Sticky Mirror trouble so LX 's may be 'Retired' !
Benz3ne
Posted 04/07/2020 - 10:17 Link
My apologies for the misunderstanding!
Hopefully you find a suitable fix. That Chinon sounds like a great option for someone looking for a film camera.
Peter Elgar
Posted 06/07/2020 - 13:31 Link
YES -- here it is with the 'Sirius' Zoom it c ame with but the Sirius has FUNGUS inside. The CHINON 50mm f1.9 is SHARP at full aperture and I took it Berlin in 2017 and got great Colour Pics.
Chinon CG-5 by Peter Elgar, on Flickr
Benz3ne
Posted 06/07/2020 - 15:14 Link
Looks very clean! I think I might keep an eye out for one myself.
Also, apologies for derailing the thread. I hope you find a suitable, inexpensive fix soon.
Peter Elgar
Posted 06/07/2020 - 16:40 Link
It was from a Widower -- he had a Ugandan Wife who died and whose camera it was hardly ever used, then my Filipina Wife fixed him up with a Filipina Wife then HE Died ! His Prostate Cancer was worse than mine and spread ---
johnha
Posted 07/07/2020 - 01:35 - Helpful Comment Link
Both my LXs suffered from sticky mirrors, I had Robin at Harrow Technical repair them (well worth it). Before the repairs, I found cycling the mirror lockup up and down immediately before shooting would often help - at the risk of more damage.
Peter Elgar
Posted 11/07/2020 - 11:40 Link
johnha -- I 'Recycled the Mirror up and down' and fired the shutter on my 1987 LX then it jammed -- the focal plane shutter has now stuck halfway across and there is a fault in the 'Capping' of the blinds so that 1987 one is now 'Nackered' !
