Archival Slide Sheets disintegrating after exposure to daylight.
Try archival polyester. Much more resistant to UV. I've not had problems with it. Like all plastics, though, there are many varieties of the basic type, so make sure it really is archival grade.
K3ii, K-5, K-x, DA150-450mm, DA16-85WR, DA16-45, DA18-55WR, DA18-135WR, DA35 F2.4, M100mm F4 Macro, DA55-300mm, FA50mm 1.4, AF360 Flash, AF540 Flash
Even if digitised, keep the originals! Archiving digital files is another can of worms.
My website
My negs, I bought these: https://www.amazon.co.uk/gp/product/B00005QFB0/ref=ppx_yo_dt_b_asin_title_o00_s0...
I have a load more slides coming soon I've purchased for my project that'll also need storing the same way
Gareth
My outfit: K1 gripped - K3ii - two Z-1P - Pentax D FA 24-70mm - Sigma 70-200mm OS HSM - Pentax modified DA* 60-250mm f4 - Irix 15mm Firefly - Pentax FA 35mm - FA 50mm - Sigma EX 20mm - FA 28-70mm f4 - Tamron SP 90mm macro - Pentax AF 540 FGZ II
My Flickr
I keep the slides I have here in plastic boxes that have an airtight lid which I store in a cool dry place with some silicone gel in them.
I used to do that but bought the A4/4-ring binder inserts from ClearFile 30years ago and
sadly chucked all the slide boxes away.
I think I have few of these, they seem to be combination of ?paper and some sort of acetate film,
OK for neg strips and 35mm unmounted slides but too fragile for mounted slides.
skydata
Member
Sussex
I packed away a few hundred E6 slides and some negative strips into 4-ring A4 binders which
were kept in the dark for many years but after some building work (DIY!) that went on for a few
years they were moved to a bedroom facing North, so never got any direct sunlight, apart from
a month or so around the summer solstice.
The folders were all piled up flat so the only the outer opening edge got any daylight.
Recently I brushed past them and a shower of plastic flakes came away onto the floor
where the very edge of each slide sheet has disintegrated.
They are made of polypropylene and one of the packs has them marked 'made in USA',
but not the other two. Another make of slide storage sheet feels as though it is different
plastic and they are fine after the same time.
How do other people store all their slides and negatives over time ?.
They are these -
https://www.ebay.co.uk/itm/265150669683?mkevt=1&mkcid=1&mkrid=710-53481-19255-0&...
