Annoying dust in MX viewfinder
Posted 30/04/2021 - 15:33
Personally I've never had any issue in giving those screens a gentle clean. Not sure if others will say that's madness, but never does any harm for me
Cotton buds seem to work
Posted 30/04/2021 - 16:00
Try taking the screen out and just giving it a burst of air first. That might work. You can get screens on ebay etc. fairly easily but be aware that although the MX and LX screens are physically the same, they do impact the exposure readings. With print film probably not enough to worry about but you'll notice it with slide film.
K.
K.
Posted 30/04/2021 - 17:40
Thanks guys, it's mainly the 'just release the catch and it drops down etc and then ...put back.......' that concerns me - is it really that easy, no shims or any other bits to fall out that I don't know about? I've been caught out in the past and I suppose I'm getting paranoid in my dotage.
Posted 30/04/2021 - 19:48
I once cleaned a very dirty focussing screen of a Nikon FE2, and had success with soaking the screen for some hours in "Green Clean" Optic Liquid, and afterwards holding the screen under lukewarm water to rinse the screen of Optical Fluid and debris. The screen was left to air dry before re-installing. I managed to remove all of the dirt on the focussing screen, without touching the screen except along the edges. No brushes, cotton buds or wipes were used. "Green Clean" make many types of optical cleaning products, amongst others DSLR sensor cleaning kits. Their Optical Fluid contains no alcohol or any other strong chemical substances.
For me the most difficult part was to remove and re-install the focussing screen. But I guess practice is the way to gain self confidence in this task, similarly to other aspects of life.
Good luck with your endeavour
Posted 30/04/2021 - 20:43
pschlute wrote:
Use air only on your screen.
Sometimes air will not be enough to remove debris from a focussing screen. In such instances I would not hesitate to once more use the method described above - not only on a Nikon FE2, but even on a Pentax SLR.
8 years
