AF with M42 Lens
tomw
Posted 30/05/2011 - 16:37 Link
Hi
Just wondering if it was possible to have autofocus with a screw mount lens by using the Pentax AF Adapter, then attaching the M42 adapter on to that, then attaching an M42 lens that has a minimum aperture of 2.8 or less.
In other words the combination would be:
Pentax DSLR + Pentax AF Adapter + M42 Adapter + M42 Lens f/2.8 or less
Would it be possible?
Tom
Anvh
Posted 30/05/2011 - 16:57 Link
With the Pentax AF Adapter you mean the 1.7x AF teleconverter?
Stefan
K10D, K5
AF-540FGZ
davex
Posted 30/05/2011 - 17:09 Link
Remember that the 1.7x does not provide full range af, you need to at least manually focus the lens to about the correct area. The aperture of the mains lens does not matter, so you should be able to do what you want;
but why ?
Davex
My flickr: link
tomw
Posted 30/05/2011 - 20:27 Link
Yes I meant the 1.7x AF Teleconverter. Silly me!
I was just wondering because apparently there was tin foil involved when you wanted to use an M42 lens with the 1.7x AF Teleconverter.
Tom
thoughton
Posted 30/05/2011 - 20:46 Link
You had it right to start with, for whatever reason Pentax called it an adapter, not a TC. works fine with M42 lenses, although see davex's post. The tin foil thing is most likely only to enable catch in focus because the painted base of takumar lenses is non-conductive.
Tim
womble
Posted 31/05/2011 - 01:45 Link
davex wrote:
... but why ?
Davex
Presumably to get AF with M42 lenses... There are some stunning M42 lenses around that produce lovely results on dSLRs, just look at the Takumar club on Pentaxforums for examples. Personally, I am happy to just use them in MF but I could see some advantages to trying this route.
K.
Stuey
Posted 31/05/2011 - 12:34 Link
I am confused by this - by af did you mean af confirmation?
I may be wrong but whilst using manual focus you can obtain focus confirmation but no lens will autofocus unless it is specifically designed to do so and have the af screw/ af mechanism in the lens etc
I am not aware of any m42 lens with this but stand to be corrected.
Incidentally I use m42 lenses and more often than not rely on eyesight over af confirmation but either seem to work.
My Flickr site link
Mannesty
Posted 31/05/2011 - 12:54 Link
You're wrong, consider yourself corrected. To be more accurate, you are correct in saying that no M42 lens is capable of AF by itself, but it can be made to AF with the addition of this.
The SMC Pentax-F 1.7x AF Adapter is exactly that, a 1.7x magnifying auto focus adapter which makes any manual focus lens auto focus, with a few exceptions listed in the documentation. EG: It would not work with my 135-600mm lens when I had it.
An MF lens does have to be partially manually focussed first to get it somewhere near focus, then the AF adapter copes fine.
To turn a screw mount lens into an AF lens you attach the AF adapter to an AF capable K-mount body, mount the K-mount adapter to the AF adapter, then screw the lens on.
Simples.
Look at the first line under General Description here.
Edited by Mannesty: 31/05/2011 - 13:04
Stuey
Posted 01/06/2011 - 12:39 Link
Simples.
Ok, I am surprised but for me to understand this how does that adapter turn the focus ring to acheive af from a manual focus lens::
Or is it a case of you having to focus close to correct and then teh adapter alter's it's own focus to compensate :
My Flickr site link
thoughton
Posted 01/06/2011 - 12:44 Link
You set the MF lens to infinity, and then the adapter has it's own lenses inside which move around when you use AF, thus bringing the MF lens' blurry image into focus. For closer objects you might have to prefocus the MF lens to somewhere close to the focus point before pressing the AF button.
Tim
davex
Posted 01/06/2011 - 13:02 Link
I can confirm it does work with the new Sigma 150-500 OS HSM.
Davex.
My flickr: link
Stuey
Posted 01/06/2011 - 21:27 Link
Every day is a school day
My Flickr site link
