Asahi Photo Solenoid Repair Asahi Photo Solenoid Repair Asahi Photo Solenoid Repair
Advice wanted re a graduated ND grad - screw fit, not gel or similar!
jeallen01
Posted 14/08/2017 - 22:55 Link
I have an ND grad with a fairly "hard" dividing line for some of the lenses - but thinking about a more progressive one for the 10-20 & 17-70 Sigmas. Filter thread sizes would around 62-72mm, and I would prefer not to spend more than about £50-60.
Not interested in gel/similar or plastic (like some Tiffen) ones as they would not last a couple of days with the way I store/use them!
So, your suggestions would be appreciated - Thanks in advance.
RobL
Posted 15/08/2017 - 13:39 Link
What do you mean, screw in? Grad filters are all square and slide into a holder, that's the only way to adjust them. Take a look at Cokin Nuances, they are glass in your price range, and get a decent filter holder to protect them! I have a holder with credit card-like pockets but the filters stick against the plastic, a lined holder like the Lee Filters one is much better.
jeallen01
Posted 15/08/2017 - 13:50 Link
Thanks but no-way will I be getting any of square filter holder systems - too much "trouble", and not enough potential use for what I would want.
And, actually, you are incorrect about there being no screw-in graduated ND filters - for example this Tiffen, although that is not the size I need.
Edited by jeallen01: 15/08/2017 - 13:56
JAK
Posted 15/08/2017 - 14:05 - Helpful Comment Link
sure?
Well these look round and screw in to me:
I believe this type were common before the square ones! These Cromofilters or similar were not usually seen above 58mm and most commonly just 49, 52 and 55mm as most lenses at the time were primes with these smaller diameters.
Trying to fit anything like these on the 10-20mm would seem to me to be a non starter though. Might be OK with the 17-70 if anyone makes/made them in the correct size (but doubt they do.)
The solution would be to seek out some primes like the Pentax 20, 24, 28, 35, 40, 50mm which would be compatible with them.
Given the dynamic range of the sensors now, do you really feel they are necessary? Just do the grad in PP. However if you are doing slide film they can be very handy as PP isn't really on with that!
Edited by JAK: 15/08/2017 - 14:09
DOIK
Posted 15/08/2017 - 14:15 - Helpful Comment Link
Have a look HERE
John
jeallen01
Posted 15/08/2017 - 14:18 Link
DOIK wrote:
Have a look HERE
John
Cheers - should have thought of SRB and the sizes look right.
jeallen01
Posted 15/08/2017 - 14:27 Link
I have the smaller variable aperture 10-20 Sigma, and it does have a filter thread on the front (in fact, a few years ago, a filter fitted there "sacrificed" itself to save the lens when the K-5 fell on the floor ).
As for primes and PP, I'm probably "too lazy" to be bothered with either most of the time (I have one prime - an old F1.4 50mm that I bought from here several years ago, and I have hardly - if ever - used it)
Edited by jeallen01: 15/08/2017 - 14:28
JAK
Posted 15/08/2017 - 14:38 Link
petrochemist
Posted 15/08/2017 - 19:26 Link
Screw on Grads have always seemed a daft idea to me. I want to compose my image to fit the frame not have to it it to the grad.
Square type filters can easily be held in front of the lens for normal range exposures - without bothering with the filter mounting kit. But I have to say software generally does a much better job than a grad can manage for anything other than a very flat horizon.
jeallen01
Posted 15/08/2017 - 19:36 Link
Still won't be going the Cokin or similar route, but maybe I should clarify a couple of points:
- I just want something I can very quickly "fish out of the bag" on the few occasions when the scenery and lighting appear to warrant it;
- I don't want to do much, and I'm totally sh1t at, PP as I don't have the skills or patience (and often the time) to do all that!
To me that means I need a quick and simple "solution" - like what I originally asked for (and so Thx to those who came up with the most appropriate ideas )
Edited by jeallen01: 15/08/2017 - 19:39
JAK
Posted 15/08/2017 - 20:20 Link
Just give it half an hour to have a play for starters. you may actually prefer it! With practice you might find you can process the image in moments. Just need to learn it!
If you go that route, take the images in raw as jpegs won't provide sufficient dynamic range. Pentax is one of the best for good dynamic range!
http://mattk.com/why-graduated-neutral-density-filters-are-dead-to-me/
jeallen01
Posted 15/08/2017 - 21:34 Link
"Each one to his own" - and PP is not mine wherever possible
RobL
Posted 15/08/2017 - 21:50 Link
I am corrected, never seen round grad filters! Obvious problem is you cannot control where the change comes, always halfway down so your horizon has to be across the middle too. I'm with jeallen01 cannot be bothered with too much time in Lightroom but once you have screwed on a square filter mount it is much quicker to change filters or add another like a full ND filter than screwing/unscrewing round ones. And of course you just need one system with different mount rings to suit the lenses. Word of caution on the 10-20mm Sigma, you risk vignetting if the filter isn't big enough so best if possible to try in a shop first.
Edited by RobL: 15/08/2017 - 21:56
stub
Posted 16/08/2017 - 00:13 Link
Your going to stuggle I think, to buy new, in glass for £50 - £60. (Hope i'm wrong). Most cost nearly as much as the lens. The two lens filter sizes are different so Im assuming your going for a 77mm filter for the 10-20 and a 72-77 stepping ring for the 17-70. Many of the cheaper filters leave a colour cast on skies..So photoshop/Lightroom may still have to be an option..
Also I will add, though you dont want square filters that the Cokin P series filters arnt wide enough for the 10-20 So only Z series would be satisfactory.
Best of luck in the search..
Stuart..
Edited by stub: 16/08/2017 - 00:16
JAK
Posted 16/08/2017 - 00:36 Link
Anything here:
http://www.amateurphotographer.co.uk/round-ups/accessory_round_ups/best-nd-grad-...
But just look at some of the prices. The Hoya circular... from around £210 !
Are you sure it isn't worth spending half an hour getting to grips with Elements? A no brainer in all honesty!
The only cheap option is to buy one of the Chinese ND Grad kits, but results can be mixed, though might be worth it to see if it's going to work for you before buying something more expensive.
Edited by JAK: 16/08/2017 - 00:39
