Advice on lens fog... balsam separation or oil condensation? Cost?
Might be worth dis-assembling the lens, I've taken quite a lot of lenses apart successfully and have been able to restore them to 'good as new', but this depends on whether it is a cemented element that is causing the problem. If it's fungus or some other surface contamination you can carefully wash in dish soap and clean water, then clean after drying with Ronsonol lighter fluid and a scrupulously clean lens cloth or lens tissue, being careful to leave no smears. Wear nitrile rubber gloves so you don't get skin oil on the lenses.
Re-assemble with care, taking note of where infinity focus is set (this is easy to adjust, usually three screws that tighten onto the focus helicoid, may need a bit of trial and error to get it right).
There should be a dis-assembly guide on the internet somewhere, try Pentax Forums. If it all fails, you've lost nothing as the lens is not usable as it is.
You guess it is balsam separation?
I don't think I will find another lens to get the cemented group, I have never seen another (in good condition) on sell... anywhere... (except Japan)
Thank David. I'm not thinking to fix it myself, I'll look for an experienced tech.
Hi Mark
I don't know without being able to see the lens and take it apart. I don't think it's oil, it could be a type of fungus, there are lots of different types that can look like haze, if it is fungus it will be clean-able so long as it hasn't etched the glass. Which exact lens is it, also how long has it been like this?
http://kmp.pentaxians.eu/lenses/ultra-wide/k20f4/
Just bought, arrived today. I'm looking if its fixable before sending it back. (Seller told it was perfect, fluid, clean, bla bla bla.. )
I would think that one will be quite easy to dis-assemble. I would be happy to take a look at it if you like, I wouldn't want to charge any money, would do it as a favour.
I'm not a professional tech, but I have repaired lots of lenses over the years and I don't take risks if the lens is difficult to take apart.
If you send it to a tech, you may end up spending a lot of money for no end result.
Just re-read your post, i.e. that you received it today. Send it back immediately, it's not your risk, the seller should have disclosed it and would have been aware of this.
Just a pity this gem will not live again.
I use 99.9% isopropyl alcohol and use that to rub the optics. Proper kills the fungus in its tracks!
Gareth
My outfit: K1 gripped - K3ii - two Z-1P - Pentax D FA 24-70mm - Sigma 70-200mm OS HSM - Pentax modified DA* 60-250mm f4 - Irix 15mm Firefly - Pentax FA 35mm - FA 50mm - Sigma EX 20mm - FA 28-70mm f4 - Tamron SP 90mm macro - Pentax AF 540 FGZ II
My Flickr
I have sent you a private message that may assist you with your issues with this lens.
I hope you can get it sorted.
Best wishes, Kris.
My website
mark88
Member
Italy
How much and can it be repaired?
Marco
