Advice from K1owners. please...
Posted 03/09/2017 - 21:22
1. Use the Auto-Focus Fine Adjustment settings for each of your lenses. It can make a big difference.
Posted 03/09/2017 - 21:45
Keep it!
Posted 03/09/2017 - 22:07
It's a good question, but the answer will depend on the individual.
For the results I want from the K-1 I shoot in JPEG with these settings: sRGB, Natural with +1 sharpness, ***quality, centre point focus, centre weighted metering, AF and exposure locked together, -0.3EV, ISO as required but generally 400.
That may or may not suit you, but I hope it helps.
Posted 03/09/2017 - 22:08
Sorry, just realised I don't qualify as a non-K1 owner ..... but I've found that advice has worked for the K7
Posted 03/09/2017 - 22:25
All your advice is always gratefully recieved Nigel, I do indeed intend to "Keep it"
Cheers Jules...
Posted 03/09/2017 - 22:26
Thanks John and I'd completely forgotten that you don't usually shoot RAW!
Cheers Jules...
Posted 03/09/2017 - 22:27
Mike-P wrote:
I know what your thinking Mike!
McGregNi wrote:
Keep it!
Keep it!
Cheers Jules...
Hows that with zooms?
Cheers Jules...
Posted 03/09/2017 - 22:53
Whatever worked for your Pentax APS-C files should work just the same for those from the K-1. They're similar, just larger!
Posted 03/09/2017 - 22:55
My experience is that if a zoom needs +10 (for example) at the long end it will also require +10 at the short end and mid zoom. Test all three, but for me the AF adjustment worked throught the range.
Posted 03/09/2017 - 23:08
A few more tips....
Getting the card out of slot 1 is more fiddly than slot 2. So i use 2 as my first card. How to make the camera record to slot 2 first.... put a card in slot2 only and switch on, then switch off and insert a card in slot 1. The camera will now use slot 2 first.
To check if you have nailed the focus you want to zoom 10x (100%). You can set the camera to snap to 10x view on one click of the rear dial.
The USER modes all start with the camera default settings including Autofocus adjustment...ie none. So if you have made numerous changes to the default settings or AF adjustments and want to retain those in your USER modes, save the USER mode by starting in Av Tv etc and then "save as" USER 1 etc.
Posted 04/09/2017 - 00:41
I duplicate RAW + JPEG in both slots, just in case one card goes bad.
Posted 04/09/2017 - 02:19
Practice outdoors in the sun or diffused light conditions to get used to the UV haze effect and adapting to them.
Storbritannia
