Digital SLR and P-TTL flash guide
Posted 04/07/2009 - 02:22
you wanna know the sick part?
took less time to read it than to print it...
I read it once and it''l take hold for life...
Posted 30/07/2009 - 10:16
ewen_r wrote:
I have noticed that my GX20 (K20d equivalent) massively under-exposes PTTL flash shots when I have a split-image focussing screen fitted.
Haven't found any elegant solution to this other than to replace the focussing screen with the default one.
Wondering if any Pentax users have seen this too?
I've had this trouble with my K10, I put the new screen in this morning and wondered why everything was under-exposed, I've put the original screen back in and it's back to exposing correctly.
I've only just bought the flash (Metz 58 ) so haven't really looked into a solution yet, I guess it could be compensated for manually but that somewhat negates buying a dedicated flash doesn't it.
Posted 30/07/2009 - 11:57
Simon,
All metering for P-TTL, as well as for non-flash metering, is performed through electronics housed in the top of the pentaprism. The same 16-segment meter sensor is used to evaluate the preflash as is used for normal exposure (though it appears that for flash exposure the whole frame is used, irrespective of the metering mode you select ). Consequently, anything that affects the mirror or focus screen can potentially affect exposure.
If you use the flash on "A", or "M" mode then there's no such problem
Posted 31/07/2009 - 00:58
Thank you so much for this. I have really waiting for this. it is much appreciated. Thank you
Posted 01/08/2009 - 16:24
Hi Matt,
That was an excellent guide !
Two things that may be worth mentioning in the next Flash Guide version is that the lightning icon in the viewfinder can disappear right after exposure for more than one reason. If the camera did not get as much flash light as it wanted (as stated in the guide), or if the flash gun needs a second or two (or three...) to recharge from the batteries. It took some time for me to sort that out... I got perfect pictures but the icon disappeared all the time. And it's hard to tell the reason, a bit confusing I think.
Also the unexpected behaviour of K10D/K20D to use some average flashlight measuring mode in P-TTL instead of the user choosen mode.
If I set the flash compensation to +1 and wireless mode (fn button) and "use built-in flash as master in wireless mode" (custom menu) in my K10D, will I get +1 for both the built-in flash and the wireless one ?
Ragnar
Ragnar
K10d, AF-540fgz, some Pentax Tamron & Sigma lenses 20-200 mm, Manfrotto tripod.
Posted 01/08/2009 - 16:45
If you ever add a chapter on advanced multi flash p-ttl set ups let us know... ps it has been a couple weeks now and Gerri is improving! I still go with everything on manual...
Posted 05/08/2009 - 05:44
Ragnar,
As far as I am aware, the compensation for slave units is only set on the flash itself. The flash compensation on the camera applies to the pop-up alone (or the flash unit on the hotshoe).
But there are other factors too... Pentax term this "contrast control" flash, IIRC.
TBH, I'll have to try it out. When I use multi-flash it's in a studio-type environment and I have everything on manual Drop me a PM in two or three weeks to remind me if I haven't updated this thread!
@Don: glad it's helped. I'll see what I can do about extra chapters
Posted 05/08/2009 - 08:11
MattMatic wrote:
Ragnar,
Ragnar,
Based on the test I ran and described last year, I believe this is incorrect.
Posted 05/08/2009 - 08:53
From your test Chris, it looks to me that
- in controller mode the remote flash is affected
- in master mode both flashes are affected
Thanks for sorting this out.
Posted 05/08/2009 - 09:25
Well in that case... the Fn control must be an overall adjustment, while the compensation on the slave itself is an adjustment relative to that slave (perhaps )
As I say, when I get a chance I'll give it a whirl with two remote flashes and see what happens
Posted 05/08/2009 - 09:43
Matt my experience is in line with your comment.
Posted 06/08/2009 - 19:30
Thanks for this I was going through hell trying to guess how to do it.
View My Flickr Photostream
Pentax K20D + BG2- Pentax DA 18-55MM AL
Posted 22/08/2009 - 17:45
Had a quick play on holiday with a single AF540...
It works like this:
* The flash exposure compensation on the camera body sets the overall flash compensation (a base-point if you like)
* The exposure compensation on the slave flash works from the base point that was set on the body.
Consequently, you can set the relative exposure balance of multiple remote flashes using the dial on each slave. You may want a master at +0, with a fill in at -2. Then you can adjust the relative exposure of the all the remotes from the body - adjusting up and down as needed.
Hope that makes sense (and agrees with what you find in practice!)
It works like this:
Posted 14/10/2009 - 20:12
Just what I needed at this moment, E-book ordered and keenly awaited. Thanks MattMatic.
Jackie H
K7, K20D, istDS, Optio SV, ME
Most used glass
50mm f1.4, 60-250mm, 28-80mm,
Most used glass
22 years
Sussex,
UK
