Wanted - Uni-Loc tripod - Major System 1600 or Major System 2300
CHEERS Vic.
PS. Good luck in finding one. (Hens teeth comes to mind)
I find the Uni-Loc range (past and present) a bit confusing. Do you have the Standard System 1700 or the Major System 1700 (I think the outer tube diameter is 30mm on the Standard and 35mm on the Major)? I guess you probably have the Standard System 1700. If so, do you find it stable enough? The Benbo Trekker I tried seemed prone to vibration at some setups, but then the outer tube diameter was only 27.5mm.
I think a Standard System 1700 would be fine for low level work and is something you could tolerate carrying with you for hours. Pity it only goes up to about 1.15m with the column down. Perhaps the solution is getting a Standard System 1700 AND a Major 2300!
These Uni-Loc tripods do come up on eBay (some at the moment). I missed a couple of 2300's recently, thinking they'd be too big, but I realise now that the 1700 would sometimes be too small.
I love the way the tripods work and am surprised how quick and easy I find them, given my normally poor spatial awareness. Mind you, I've only just discovered the way the legs go through 360 degrees, so you don't have to move the head to the other end of the column when you switch between working high and low!
CHEERS Vic.
Sorry, so many questions, just when the Standard System1600/1700 come up on eBay I wonder if I should be holding out for a Major System version.
CHEERS Vic.
If you haven't used a Uni-Loc/Benbo before - be very careful when setting it up. Don't let go of the camera until you've tightened the bolt properly and made sure the setup is balanced before letting go (you can set them up in unstable configurations without really thinking about it) - it can feel like wrestling with an octopus in a soap factory sometimes!
John.
I have the Standard 1700 System (but wished I'd bought the Major 2300 when I moved into medium format), that said I'd be happy to put the P67 on top of it. I did compare the two at the time - the 2300 was a serious piece of metal.
John.
That's another thing Charlie. Until you get used to it add in a couple on gallons of motor oil and John is right. (Demented Octopus comes to mind) Don't give up on it though because once you are used to it they are just great.
CHEERS Vic.
I can see why the bendy joint (with the extra head mount screw at 90 degrees) on the System tripods would be very helpful.
John.
So true!! I have a Uni-loc (from about 1997), but am not sure which system it is. They do require attention and practice.
Mine doesn't go very high; ie I am a tad under 6 foot and sometimes have wished the tripod could go about 3 inches higher
Hello,
I have a Major System 2300 for sale. I'm new to this site so cannot send PMs. If you contact me, I'll send you links to photos.
Regards,
Sash
Perhaps I should have held out for the more versatile Major System 2300. I find the fixed-length column on the standard Major 2300 a bit long but it literally takes a minute to swop in the column from the Major System 1600. It's effectively a Major System 1600 with longer legs, which is a great setup.
I know these sort of tripods aren't for everyone but, once you get the hang of them, I think they're brilliant to use and a fantastic bargain when you can pick them up off eBay for as little as £20.
And P&P a lot more than that at a guess?!
12 years
Cambridge
I might consider the Benbo 1 / Benbo 2 but the Uni-Loc System has a few advantages over the Benbo. I won't consider the Benbo Trekker - I had a look at a friend's Trekker and at full height, even with the column down, the vibration was a lot worse than on my Velbon Ultra REXi L travel tripod.
