New k3 1.21 firmware
I have tried with various lenses attached but still get the same outcome. Not sure if it is a firmware glitch or my camera. Awaiting an answer from Vic to see if he has the same problem or not.
Everything else appears to be OK
Martin
I dont have same problem update seems fine
I have just deleted the comment as I moved the mode switch from AV to P and tried again and all seems fine now. Have gone back to AV and tried again and it works OK, as it it does in all modes. :
Martin
I did run a manual dust removal a couple of times after the mode change and also switched it off a couple of times as well .. not sure if that made any difference. Perhaps a complete battery removal and replace might do the trick ... worth try at least.
Strange !!!
Herefordshire
